ThinkJet 2225B Battery Pack 82199A Repair Message #1 Posted by Dan Grelinger on 19 Apr 2008, 12:01 p.m.
I recently replaced the Ni-Cd cells in my ThinkJet IL printer and thought that others would benefit from my experience. I purchased a pre-assembled pack, with connecting wires, from www.onlybatterypacks.com They have a version that is easily modified for the 82199A. It is item number 10515 (or #2406F) http://www.onlybatterypacks.com/showitem.asp?ItemID=10515 . The hardest part is removing the plastic that they used to cover the assembled pack. Once you do that, the batteries can be easily positioned properly for the 82199A without any soldering, desoldering, or resolding of the tabs. Order it with the solder tabs on the connecting wires, and then you will only have to add the existing 82199A fuse inline when you solder it into the pack. Total cost is $26.05 including shipping. the cells are rated at 2400mAh.
Dan
