Re: HP67 Moon Rocket Lander. Message #6 Posted by Bob Frazee on 5 Apr 2008, 8:50 p.m., in response to message #5 by Bob Frazee
Well, lets try this again.
Mike
Line 067 should be 31 25 04 (f lbl 4), instead of 34 04. I ran the program like you described, on a real 67 and your emulator gets the same numbers as the real 67. I also entered 2, 20 unit burns and the velocity and altitude numbers matched, although to get the burns entered, I had to enter the first digit, which stopped the program, then entered the burn again, then hit r/s. The real calculator takes the burn that was entered during the "0" pause, and keeps on going, no r/s is needed to keep the program running. Hope this helps.
Bob Frazee
