Re: HP 150 touchescreen Message #4 Posted by Pascal on 9 Apr 2008, 1:33 a.m., in response to message #3 by ffabrizioluga
Teledisk normally works fine, I have used it to create several floppies for the HP-150. You need to use an old 3.5" floppy drive that can read/write low density disks, If you use a 486, there are good chances that it will work.
During the creation of the floppies, Teledisks gives error messages because the format is not recognized by DOS but you can ignore the messages. For some images it displays an error message after each sector but you can press a key and ignore it. At the end of the creation, it also says it cannot read the floppy but ignore this message as well, the floppy should be good for the HP-150.
