Can anyone check this strange behavior on HP-15C Message #1 Posted by Bastian Erdnüß on 16 Mar 2008, 10:47 a.m.
I have an HP-15C. I wrote the following program (a nimb game):
LBL A: 01 - 42, 21, 11
1 002 - 1 Start with 15 sticks
5 003 - 5
LBL 0: 004 - 42, 21, 0
R/S 005 - 31 User enters no of taken sticks
ENTER 006 - 36
INT 007 - 43, 44
ABS 008 - 43, 16
X =/= Y: 009 - 43, 30, 6 Make tests for correct insert
GTO 1 010 - 22, 1 GTO 1 -> Error!
X == 0: 011 - 43, 20
GTO 1 012 - 21, 1
CLX 013 - 43, 35
4 014 - 4
X <= Y: 015 - 43, 10
GTO 1 016 - 22, 1
ROLL DOWN 017 - 33
- 018 - 30 Calculate left sticks
X <= 0: 019 - 43, 30, 4
GTO 2 020 - 22, 2 Nothing left -> User lost
PSE 021 - 42, 31 Show left sticks
ENTER 022 - 36
1 023 - 1
- 024 - 30
X == 0: 025 - 43, 20
GTO 3 026 - 22, 3 If computer takes last -> user won
4 027 - 4
/ 028 - 10
INT 029 - 43, 44
4 030 - 4
* 031 - 20
1 032 - 1
+ 033 - 40
X =/= Y: 034 - 43, 30, 6 If possible take optimal no of sticks
GTO 0 035 - 22, 0 -> next round
1 036 - 1
- 037 - 30
RAN # 038 - 41, 36 Otherwise, take random no of sticks
3 039 - 3
* 040 - 20
INT 041 - 43, 44
- 042 - 30
GTO 0 043 - 22 0 -> next round
LBL 1: 044 - 42, 21, 1
0 045 - 0 -> Error!
LN 046 - 43, 12
LBL 2: 047 - 42, 21, 2
5 048 - 5 Show BLISS
5 049 - 5 -> Computer has won
1 050 - 1
7 051 - 7
8 052 - 8
RTN 053 - 43, 32
LBL 3: 054 - 42, 21, 3
3 055 - 3 Show ILOSE
5 056 - 5 -> User has won
0 057 - 0
7 058 - 7
1 059 - 1
RTN 060 - 42, 32
It's a rewrite from the program from Genes HP.
The rules are easy:
1) Start the program.
2) 15 is shown.
3) Enter no of sticks you will take (1, 2 or 3).
4) DO _NOT_ CONFIRM WITH ENTER
5) press R/S.
6) The no of remaining sticks will be shown for a short time.
7) The no of sticks remaining after the turn from the computer is shown.
8) Go on by step 3)
9) If you do a wrong insert, Error 0 is shown, you lost.
10) If you have won, ILOSE is shown (upside down).
11) If you lost, BLISS is shown (upside down).
Now, my problem is the following: If I start by taking 1 or 3 sticks, all works fine and I lose.
But if I start by taking 2 sticks (the only chance to win the game), the computer will not take any stick. It seems that the test in line 34 does not evaluate right. But If I step the program, all works fine.
In the second round (and in all following) it than seems, that the ENTER in line 22 will not be executed right (so the test in line 34 fails again). Again, if I step the program, this happens not.
I guess that something may be weak in my computer, but what? It seems not to be the test (in line 9 it works very well, and replacing X =/= Y in line 34 by X >= Y doesn't changes anything). It also seems not to be the ENTER key, because in line 6 it works well and in the usual calculating also.
Or did I misunderstood something in the way my computer works and did a mistake in the program? Can anyone check this?
Has anyone a idea what could make this behavior?
Thanks, Bastian.
