HP User Contributed Programs Message #1 Posted by Bill (Smithville, NJ) on 15 Mar 2008, 7:06 p.m.
I have finished scanning in the first 13 of the HP User Contributed Programs that I recently received. The programs are as follows:
00057C Chebyshev, Legendre, Hermite & laguerre Polynomials
00060C Bessel Functions, Error Function
00320C Linear Programming using Simplx Algorithm
00327C Straight Line Forced thru Any Point
00341C Modified Crescent Curve Fitting
00351C Area Under Curve
00390C Roots of Polynomials
00397C Piloted Linear Regression
00407C Characteristic Polynomial of a Square Matrix
00477C Curve Fitting
00555C Multiple Linear Regression
00556C Polynomial Regression
00609C Fitting Polymonials of Degree M to Data
Each program has been entered into the V41 HP-41 emulator and the file saved in RAW format. HP41UC was used to create a text file of the program listing and to create PCL and PS Barcode print files.
The result is a Zipped up package of files that includes a scan of the original library submission, RAW file that can be used in an emulator, a program listing, and files that can create Barcodes so that the wand can be used to directly input the programs into an actual HP-41C.
These will be uploaded to Dave for inclusion in the next version of the HPMuseum's DVD's
If anyone would like a copy of any of the above programs, please E-mail me through the HPmuseum and I'll email you the zipped up file.
Thanks,
Bill
