HP71b - Forth Modul Message #1 Posted by Roland Storz on 9 Mar 2008, 2:49 p.m.
can anybody help out,
I'm starting to use the Forth Modul together with the HP71b.
I did start to write some Forth programs as Text files using the Texteditor (which is embedded in the Forth Modul as well).
However, I do not know what exactly to do with the Text files in the Forth environment.
How to load them, how to compile them in order to run programs within the Forth environment?
Many thanks for any help in advance,
Roland
