Re: HP 50g finding the nth derivative Message #2 Posted by Mark W Paris on 10 Mar 2008, 10:56 a.m., in response to message #1 by Jonathan Vogel
Hi Jonathan -- I don't know if there's a key-sequence that'll do it for you, but I tend to doubt it. I checked the manual and didn't find any f^{(n)} function.
You can write a short program using matrix functions to do it.
Suppose you want the n-th derivative. The brute force way of doing this is to evaluate the function at n+1 points and take the finite differences dividing out (for n>0) some appropriate interval. Eg.
f^{(1)}(x) = \frac{f(h)-f(-h)}{2h} (LaTeX form - should be pretty obvious)
The error in this equation is O(h^2) since we've taken the symmetric diffrence.
Now if we truncate the Taylor expansion for a function f(x) about a point f(x_0) at order n
f(x)-f(x_0)=\sum_{m=1}^n f^{(m)}(x_0) x^m/m!
we can write a linear system of equations for the derivatives f^{(m)} for m>0 in terms of the differences of the function evaluated at x_0 and multiples of some small number h as
f^{(m)}(x_0) = \sum_{j=1}^n A^{-1}_{mj} [f_j-f(x_0)]
where f_j = f(x=j*h) and A^{-1} is the inverse of the matrix
A_{jm} = (j*h)^m/m!
The method is accurate to O(h^(n-j)) for the j-th derivative.
There are some tricks you can play to improve the accuracy of the algorithm, like taking symmetric intervals about x_0, ie. x=+/-h, x=+/-2h, x=+/-3h, ... but the idea is the same.
Of course, as always, you should check any math people tell you yourself.
