MLDL2000 new software coming soon Message #1 Posted by Meindert Kuipers on 6 Feb 2008, 1:43 p.m.
I will release a software for the MLDL2000 in a few weeks. I am currently working on the following features:
- support for MOD files (reading and writing)
- create and restore backup of MLDL contents
- firmware programming
Possibly there may be a few other small improvements. If there are suggestions, please let me know so I can consider them for inclusing in the next release.
The upcoming software release will be the last one before the MLDL2000V2. V2 seemed a bit tougher than I expected, but I think I have the architecture figured out and I will start prototyping after I have released the new MLDL2000 software. With only a new USB print everything can be fully backwards compatible, so the upgrade for new users will be pretty cheap. Also software and firmware will be the same for both versions. Some of the new features will require a new CPDL print as well, but the main upgrade, use of (micro)SD cards with the HP41, will still be possible with only the replacement of one PCB.
In case you have not noticed: my website has moved to www.kuiprs.nl.
Meindert
