Re: HP-41 Program conversion to Text files Message #9 Posted by Eric Smith on 27 Jan 2008, 3:08 p.m., in response to message #1 by Jeff Davis
Are you trying to run the 41 programs on the 71 using the HP-41 Translator Pac? If so, use the READ41 program in the Translator Pac.
Other than that, if you have an 82164A HP-IL to serial converter, you can use the PRP ("PRint Program") function to send the program as text to the serial converter, to be captured on any kind of computer with a serial port.
If you have either the 82164A or a 9114 disk, you use Tony Duell's life_utils on a PC running Linux to capture and decode it (lifget and prog41). Perhaps someone has ported lif_utils to Windows or DOS, or perhaps equivalents exist.
