HP17BII+ enter key Message #1 Posted by Mvdn on 10 Jan 2008, 1:59 p.m.
I was looking forward when i would be available : 'the new HP 17 BII+' Now I took a clser look and saw the enter key is bottom right. It's a sham it isn't where it belongs (where the input key is). Same mistake they made with the 33s but we could manage that easily with some programming.
R/S key alias Enter Key
Go into PRGM Mode (Left Green PRGM)
LBL A - (Left Green LBL A)
You can use any label A-Z
R/S
ENTER
GTO A (Left Green GTO)
Exit Prgm mode (Left Green PRGM)
Now any time you want to use the R/S key as the ENTER function just press XEQ A.
You need the XEQ A to assure your R/S as an enter does not start in some undefined program you have loaded.
Picture of new HP HP 17BII+
