Re: HP50g Statistics Application Message #4 Posted by Giancarlo (Italy) on 7 Dec 2007, 2:28 a.m., in response to message #3 by sam
Hi Sam.
If you press the [VAR] key, then you'll enter the VARiable browser. If necessary, press [NXT] to browse thorugh the variables stored in the HOME directory till you see tha SigmaDAT one (please note that here "Sigma" just stands for the Greek capital letter Sigma - so you're gonna see on the display a Greek capital sigma letter plus the "DAT" suffix).
Then you will want to press:
[LEFT SHIFT][+] @puts a pair of curly brackets on the command line
the [F1]...[F6] key corresponding to the SigmaDAT variable
[ENTER] @to terminate command line input
[TOOL] @to bring back the "basic functions"
[F5] @the "PURGE" key
and you're done!
By the way, if the above does not brings you out of trouble, you may want to consider the following:
1) try to issue the CASCFG command (you may pick it from the [CAT] list you get by pressing [RIGHT SHIFT][]SYMB] - it will "re-configure" the CAS settings
2) try to do a warm reset by pressing: [ON]+[F3] - this will "re-boot" the 50G
3) try to do a full reset by pressing: [ON]+[F1]+[F3] -
WARNING! This will reset the 50g to a nearly "out-of-the-box" state !!
Hope this helps.
Best regards.
Giancarlo
Edited: 7 Dec 2007, 2:34 a.m.
