HP Forum Archive 18
TOPCON HA-3 with HP-71B
Message #1 Posted by Jeff Davis on 1 Dec 2007, 9:21 a.m.
I have one of these units and was wondering if there is a manual out there somewhere for this unit. Also, is it possible to upload and download files to a PC? This unit has an RS-232 port and cable to connect to the PC. Any thoughts? Thanks, JeffD
Re: TOPCON HA-3 with HP-71B
Message #2 Posted by Eric Smith on 1 Dec 2007, 8:02 p.m.,
in response to message #1 by Jeff Davis
I've never actually seen one of those, but I've gotten the idea from somewhere or other that the serial interface is compatible with the 82164A, so the usual methods should work. I think there have been postings in this forum about that.
I think you can upload a text file to the PC using something like:
COPY FOO TO :INTRFCE
For BASIC programs, you're best off using TRANSFORM to convert them to/from text. I'm not sure if you can do this directly to/from the serial interface, so you might have to do it in memory first.
