Re: HP49g keyboard shortcuts Message #2 Posted by Dave Britten on 18 Nov 2007, 9:08 p.m., in response to message #1 by Alexander DeLarge
Here's a few more I use.
L-shift[hold] MODE - Old Modes menu from 48S/G (L-shift CST on 48G)
R-shift[hold] 9 - Old Time menu from 48S/G (L-shift 4 on 48G)
R-shift[hold] 7 - Assorted solver menus (can get to the original 48S solver in here)
There aren't any hidden shortcuts for the old 48S/G Plot and Stat menus, unfortunately, but you can assign short programs to keys of your choice to pull them up:
\<< 96.01 MENU \>>
83.3
ASN
...Gives you the Stat menu on USER R-shift 5, for example. Add a SysRPL takeover to the program object to make this work even if you're in an editor (use the \->TO? command from the Keyman library.)
