Re: Repairing the hp 82104A Card Reader Message #2 Posted by Randy on 14 Nov 2007, 7:42 p.m., in response to message #1 by fred moon
They must be straight, any bending or fiddling with those springs will bring you nothing but misery.
If you've bent them in an attempt to make it work, you probably have the two small whiskers bent at too sharp an angle which reduces the amount of bow thus preventing contact.
The only other thing might be improper position - with the small end not in the slot of the actuator cam.
