Re: Book(s) related to HP calculators history ? Message #2 Posted by Allen on 30 Oct 2007, 5:46 p.m., in response to message #1 by Jean-Michel
http://www.hpcalculatorguide.com/ is probably your best bet. There are some areas of the book that are not factual (e.g. subjective observations or authors opinion), but for the most part it is a very good historical reference. I have read nearly all of it, and would recommend it as part of any serious collector's library.
Edit: I should warn you, since it is a 5th edition, you will notice that the flow of the book is not smooth, since it is an expanded version, but not thoroughly revised. If you read it in one setting, you will notice the patch-work of chapters and will see some material repeated every 40 pages or so.
Edited: 30 Oct 2007, 5:54 p.m.
