Re: Retooling a HP 12C Message #8 Posted by Eric Smith on 28 Oct 2007, 3:47 p.m., in response to message #7 by Hugh Evans
I've even found old voyagers that don't feel quite as good as others.
That's not surprising, if one has had more wear than another. The life of the domes isn't n cycles without no change and then sudden abrupt failure. They degrade (wear) with use.
The question is how much variability was there when the Voyagers were new, and I think the answer is "not much". I used perhaps two dozen Voyagers before 1986, and there were no noticeable differences in key feel at the time.
But is the performance of the domes in a new 12C (not 12c Platinum) significantly different than the original dome performance of a 12C made in the early 1980s? If they have been redesigned using different domes (or no metal domes), they could be noticeably different. I haven't used any new 12Cs in a long time. The 12c Platinum keyboard does not feel quite the same to me as the original Voyagers.
The company I chose for OpenRPN is Snaptron.
Based on experience, or just on the published specifications? Most if not all of the dome vendors offer similar specifications. As it happens, I was considering Snaptron as well, though I haven't yet evaluated their products.
