Re: "14B - Fail 8" Message Message #2 Posted by Miguel Toro on 15 Oct 2007, 2:35 p.m., in response to message #1 by Barbara Kanu
Hello Barbara,
Actually, this is the kind of message that you receive after a failed self-test. To clear it, you have to press and hold the "C" key and press the "PV" key then release both. If that does not work you can try this: press and hold "C", press and hold "N" and press "E+" (the summation key) then release them. That should reset the calculator and clear the memory.
There must be a problem with the machine. Try the self-test again with "C" + "PMT" for you to see if you get the error message again.
Miguel
