Re: HP 35s On/Off /Clear x reg Key Message #2 Posted by Karl Schneider on 15 Oct 2007, 7:52 p.m., in response to message #1 by DavidB
"DavidB" --
This has been mentioned before; it's a detail that was overlooked in the HP-35s , but not in the predecessor Pioneer-series models (e.g., HP-32SII), or even the HP-33s.
This may have been partly due to expedience in manufacturing: Only yellow is printed on the faceplate, but "a b/c" doesn't require the yellow shift key.
As you noted, either the yellow shift key or the blue shift key will work when turning the calc off. One can also pointlessly press the blue shift key prior to turning it on. So, the respective printed colors of "OFF" and "ON" are not technically incorrect, while "a b/c" in yellow actually is.
-- KS
Edited: 15 Oct 2007, 7:54 p.m.
