Re: Hp 50g: How do I clear a Matrix inside Matrix Writer Message #2 Posted by Hal Bitton in Boise on 24 Sept 2007, 10:16 a.m., in response to message #1 by Miguel Reznicek
Hi Miguel,
When you exit the matrix writer (such as when you run stats on your dataset), it clears. It will then re-open to a blank pallet.
For this reason, any matrix you want to keep must be put onto the stack (by pressing enter a second time in the matrix writer), and then saved into a variable (or you could just save it on the stack I suppose) Best regards, Hal
