Re: HP-48-SX/User Assigned key comands Message #2 Posted by Raymond Del Tondo on 15 Sept 2007, 8:04 p.m., in response to message #1 by Hai Quan
There are various reasons why your attempt doesn't work.
1. CLX is _not_ an HP-48 command
2. You used double quotes, so you wanted to return a STRING
Solution:
1. Use a valid HP-48 command, like DROP in this case
You can create an unevaluated command on the stack this way:
{ command_name } OBJ-> DROP, where command_name is your actual command.
Then you specify they key to be assigned, e.g. 11.1, then ASN.
Alternatively you can embed your command into a program like this:
<< command_name >>
HTH
Raymond
