Re: Program format from 33s to 35s Message #2 Posted by Karl Schneider on 15 Sept 2007, 6:31 p.m., in response to message #1 by romeo_charlie
Welcome, Rafael!
Unfortunately, I am just an airline pilot, and am no computer or math expert.
Certainly no need to be humble about that...
Now, I have just bought a 35s, and have found that the polar to rectangular conversion just doesnt work the same way (as it did in the HP-33s).
Yes, this has been source of considerable consternation in this group. I belive that it was a horrible idea.
I've also had to deal with that same issue while porting my HP-32S/32SII/33s program to the HP-35s. The basic problem is that while "Th,r->y,x" and "y,x->Th,r" utilize only two stack registers, the conversion procedures that would be employed on the HP-35s almost always require more. This might cause the program to fail, by causing stack overload.
If the program were optimized for the HP-35s, many of the conversions could be eliminated, with calculations done using complex numbers in polar mode. But that would take some effort.
Polar to rectangular:
I replaced "Th,r->y,x" with code that used all four stack registers.
(magnitude)
ENTER
ENTER
(angle value)
ENTER
SIN
x<>y
COS
Roll_up
* (result is x-coordinate)
Roll_down
* (result is y-coordinate)
For two-level calculations, an alternative is to store results and inputs to lettered registers, then recall them as necessary:
(magnitude)
STO M
(angle value)
STO A
SIN
x<> M
RCL A
COS
RCL M (result is y-coordinate)
Rectangular to polar:
The difficulty is that ARG (or conversion to polar representation of a complex number) is the only way to access the "atan2" function, which gives the proper quadrant of the angle -- very important in navigation.
Using complex-valued functions, with one extra stack register:
(x-coordinate)
(y-coordinate)
i
ENTER
ABS (result is magnitude)
x<>y
ARG (result is angle value)
To use only two stack registers will require a storage register and a bit more thought...
I hope I am not bothering the audience with my ignorance about HP calculators.
Thanks in advance for any help.
Not at all; our pleasure.
-- KS
Edited: 15 Sept 2007, 6:50 p.m.
