Re: Could I use AA alkaline batteries in a HP 35? Message #6 Posted by Jeff O. on 15 Sept 2007, 7:54 p.m., in response to message #5 by Miguel Toro
If I recall correctly*, a fully charged nicad puts out about 1.5 Volts. If you check the schematic of the classic charger, it indicates that the logic supply voltage is 4.2 Volts. Based on this information, it is hard to believe that 4.5 Volts would present any danger. However, better safe than sorry, so unless you have a strong need to use alkalines, why take the risk. It would also be bad if you happened to plug the charger into your calculator with alkalines installed.
*-which I apparently do not, see below
Edited: 15 Sept 2007, 9:04 p.m. after one or more responses were posted
