Maybe...(was: MLDL2000 Problems) Message #6 Posted by Vieira, Luiz C. (Brazil) on 14 Sept 2007, 6:34 a.m., in response to message #4 by Jeff Davis
Hi, Jeff;
Just to make sure I understand: based on your post, should we consider you are connecting the MLDL2000 to the computer through USB when it is not connected to the calculator? If I am not wrong, the unit must be connected to the HP41 when connected to the computer (must check if it is valid for your unit). I've always connected mine to the computer when it is plugged in the HP41, cannot tell what happens otherwise.
Another point: as Meindert mentioned, chances are that the SRAM backup .1F capacitor is not properly connected (broken solder?); this way it would not be possible to hold SRAM contents when it is unplugged.
As a final suggestion, do you have another HP41 for a single test? If port #4 has problems in one calculator, chances are that you have success with another. You see, I myself see no practical solution if testing with another HP41, but after reading about some unknown problems when broken posts are the issue, I believe in anything...
Success!
Luiz (Brazil)
