Re: Computing many digits of Pi Message #18 Posted by Egan Ford on 18 Sept 2007, 10:35 p.m., in response to message #1 by Juan Pablo Martinez (Spain)
Using the Spigot Algorithm from Pi Unleashed + HPGCC I can compute 15000 digits of PI in 412 seconds on my 50g. If you are interested I can send you the binary so that you do not need to compile and install the ARM Toolbox. NOTE: Real 50g/49g+ required.
To use:
15000 pidf
Output to stack:
bytes used: 210056
time(s): 412
digits: 15000
digits/s: 36.41
SD card will have file PIDIGITS.TXT with the output formatted with 32 digits/line, recall to stack with:
3:PIDIGITS.TXT RCL
Up Arrow VIEW to see all digits.
NOTE: HPGCC binaries can be large. Best to store on SD card and run with:
3:pidf EVAL
Put that in a small UserRPL script and save to main memory.
You can hold down any key (but ON) to stop the run and collect partial output. When done exit with ON.
pidf.c
Get n from stack and compute n number of pi digits using
Spigot method from Pi Unleashed by Jorg Arndt & Christoph Haenel.
Mem allocated = ((n/4)+1)*14 * 4 bytes
Return to stack statistics, e.g.
(n=5000):
bytes used: 70056
time(s): 46
digits: 5000
digits/s: 108.70
(n=15000):
bytes used: 210056
time(s): 412
digits: 15000
digits/s: 36.41
Only HP specific comments, read book for algorithm details.
#include <hpgcc49.h> //the standard HP lib
int main(void){
int *a;
int b;
int c;
int d = 0;
int e = 0;
int f = 10000;
int g;
int h = 0;
int start;
int end;
int cc = 0;
char buf[40];
int ndigits;
FILE *fh;
char *filename = "pidigits.txt";
sys_slowOff(); //max speed
clear_screen(); //clear the screen
if((fh = fopen(filename,"w"))) {
else {
printf("Error opening %s\n",filename);
beep();
sys_slowOn(); //normal speed
WAIT_CANCEL; //loop until ON pressed
return(1);
ndigits = sat_pop_zint_llong(); //get ndigits from stack, must be int > 0
if(ndigits > 0) {
else {
printf("Number of PI digits must be an\ninteger > 0!\n");
beep();
return(1);
c=(ndigits/4+1)*14;
a=malloc(c*sizeof(*a));
start = sys_RTC_seconds(); //get start time in seconds since 1/1/1970
while ((b=c-=14) > 0) { //logic, compute 4 digits of pi at a time then display
while(--b > 0) {
d *= b;
if (h == 0)
d += 2000 * f;
else
d += a[b] * f;
g=b+b-1;
a[b] = d % g;
d /= g;
printf("%04d", e + d/f);
fprintf(fh,"%04d", e + d/f);
cc+=4;
if(cc % 32 == 0) {
printf("\n");
fprintf(fh,"\n");
if(keyb_isAnyKeyPressed()) //hold any key to stop, do not use ON
break;
d = e = d % f;
h = 4;
end = sys_RTC_seconds(); //get end time in seconds since 1/1/1970
fprintf(fh,"\n");
fclose(fh);
printf("\n\n");
sprintf(buf,"bytes used: %d",(ndigits/4+1)*14*(int)sizeof(*a));
printf("%s\n",buf);
sat_stack_push_string(buf); //push string to stack
sprintf(buf,"time(s): %d",end-start);
printf(" %s\n",buf);
sprintf(buf,"digits: %d",cc);
if(end-start == 0)
sprintf(buf,"digits/s: NAN");
else
sprintf(buf,"digits/s: %.2f",(float)cc/(float)(end-start));
printf(" %s",buf);
beep();
return(0);
Edited: 24 Sept 2007, 11:37 a.m. after one or more responses were posted
