Re: HHP-16K 41C ROM Emulator Message #3 Posted by Winfried Maschke on 11 Sept 2007, 10:04 a.m., in response to message #1 by Ron Fredericks
Anyone know how to configure the dip switchs for some valid combinations of eproms?
I know only one switch setting for a 16K EPROM-Set with 2x2764 and 1x 2732.
The left 4 switches on the picture in your blog are selecting the type of EPROM-Set. 1 up, 2up, 3 down and 4 down is 16K. Only switch 2 has to be different to the picture.
With the other bank of switches on the right side you can select between port 1+2 or 3+4 in this case.
