Re: I have found....but... Message #4 Posted by Vincze on 7 Sept 2007, 1:56 p.m., in response to message #3 by Valentin Albillo
I will do what you say my friend, but I able to copy the text from your PDF with an open source PDF viewer, so should be correct, if the PDF is correct. Regardless, I check lines you state.
With real 71B, how does one store program with card reader? I not find instructions in two manuals I get with unit, so I wonder if there is another manual I need to find this information out.
**EDIT** I see that in my program, 80 - 82 were not "exact" as it look like you have some lower case and some upper case. I have all uppercase. I retype to exactly what you have, still no luck.
Just curious, what does 80 - 82 do? It look like garbled text.
Edited: 7 Sept 2007, 2:06 p.m.
