Re: 35s storage Message #6 Posted by Earl Kubaskie on 25 Aug 2007, 10:55 p.m., in response to message #4 by Alain Mellan
If you have a list with Item 2, Item 5, Item 203, Item 1425, etc. then Alain is right on the money. The vector method he advised especially allows you to use higher accuracy in your ascension/declination values than 1 decimal place.
But are your item numbers a continuous 1, 2, 3, ... etc. series? If so, your program could encode the item number into the register number, allowing the 3rd portion of the 3D vector to be used or reserved for additional data.
