HP 32Sii Troubleshooting - Does not turn ON Message #1 Posted by recnadniar on 25 Aug 2007, 10:35 a.m.
I've had my 32Sii for nearly 10 years now, and it has worked without fail until just a few days ago.
when I pressed the ON button the screen was very dim. I tried to adjust the contrast,I put in a set of fresh batteries, tinkered with it, all to no avail.
Anyways, I found a simple fix to the problem. I used a fine grit sandpaper to scour the battery terminals. the terminals looked clean, and shiny so I did not think it would actually work, but miracle, my trusted HP32Sii came back to life.
Hope this will help somebody with a similar problem.
