Re: 71B case question Message #4 Posted by Maximilian Hohmann on 24 Aug 2007, 12:42 p.m., in response to message #3 by James M. Prange (Michigan)
Quote: If you can find a model with all dimensions the same or slightly larger than the 71B's, then its case ought to work.
I don't think that there is an hp calcualtor that resembles the 71B in size even closely... The unusually sized 19C is still smaller (and harder to find than the 71 anyway), even the 200 LX is smaller!, and the 75 and 91/92/97 are much larger.
The only calculator that I can think about now that is about the size of the 71 is the Psion Series V palmtop. There are quite a few third-party pouches for Psions to chose from, but I would try it first in the shop.
Greetings, Max
BTW: I have the same problem with my 75C - no case and a very, very unusual size!
