Re: Things 35s - Purely Superficial... Message #12 Posted by Vincze on 19 Aug 2007, 7:03 p.m., in response to message #11 by Egan Ford
The process of inserting the spiral binding is manual (I've watched them before). I speculate that you could order any color, size, and type (metal or plastic) online and put it on yourself.
Yes, I have seen done too. Not with plastic spiral though, but plastic coated metal I believe, and then use needle nose pliers to put slight bend so spiral do not come out. I guess you could always have them bind for you with black, and when you get white spiral, you could remove black, and insert yourself.
