Emu28 MRU setup Message #1 Posted by Christoph Giesselink on 27 July 2007, 5:48 p.m.
Configuration of the MRU (Most Recently Used) file list in Emu28 v1.15.
By default Emu28 is using maximum 4 MRU files. This behavior can be changed from disabling the MRU list to the number of lines limited by your current desktop resolution.
To change this
- close all Emu28 sessions
- open the file Emu28.ini in your windows directory
- goto the [MRU] section inside the ini file
- change the number of the "FileCount=4" setting
- save the ini file
- restart Emu28 now using the new settings
Valid settings for "FileCount":
<0 = forbidden
0 = disable MRU list
>0 = maximum number of MRU entries in the "File" menu.
The MRU file list is saved in the MRU section of the ini file as "File1=", "File2=", ... When decreasing the number of MRU entries you should manually delete the become redundant "FileX=" lines.
Don't be sad, all other of my emulators will get the MRU file list also.
Christoph
