Re: HP32SII Keyboard fix Message #3 Posted by y.miyata on 2 Aug 2007, 2:53 a.m., in response to message #2 by Curtis Tom
> "... tighten the lower three metal tabs that hold the LCD to the circuit board."
I'm very interested in this, because mine has the same problem with the keyboard.
How can I find "the lower three metal tabs"? Do you mean that the calculator should be disassembled to access the metal tabs ?
Thank you very much in advance, Sincerely
