Re: 48GX, TDS RAM Card, Low Batt Indicator Message #2 Posted by James M. Prange (Michigan) on 14 July 2007, 11:52 p.m., in response to message #1 by Ron G.
Does it still show the low battery indicator with the card removed?
Do you mean a ROM card by any chance? If so, then maybe try a warmstart by holding down the ON key, pressing and releasing the C key, and finally releasing the ON key. If that doesn't help, you could try archiving user memory, then doing a user memory clear by holding down the ON key, pressing the A and F keys, then releasing first the F key, then the A key, and finally the ON key, and then pressing the NO menu key in response to the "Try To Recovery Memory?" message.
All RAM cards do have a battery, but I seem to recall that some cards use a non-replaceable battery, intended to last for the "life of the product". In other words, if you can't replace the battery in your RAM card, then it's lifetime is over.
Regards, James
