Re: HP 50g DMS Message #6 Posted by Peter A. Gebhardt on 5 July 2007, 5:26 a.m., in response to message #5 by Jeffrey Connor
Jeff,
in RPL mode enter HH <space> MM <space> SS <Custom Function>.
If your custom function has been built with (say as an example)
DEFINE('K(h,m,s)=h*3600+m*60+s')
in algebraic mode (which I suppose, because of your question), calling your custom function as described above will solve the RPL equation:
<< -> h m s 'h*3600+m*60+s' >>
and display the expected result.
For a description on DEFINE see Chapter 3 of the User Guide (the large pdf document on CD).
For a more user-friendly implementation, pls. look up the fine descriptions of - '30 MENU' usage in equations - to build custom menus. A lot of sophisticated samples of this technique are available at
http://groups.google.com/groups/search?q=30+menu&qt_s=Search+Groups
Hope this helps!
Peter A. Gebhardt
