Re: HP 35S site withdrawn Message #2 Posted by Karl Schneider on 10 June 2007, 4:00 p.m., in response to message #1 by Sam Levy
Did HP pull the site over criticism? Would they revise it?
Maybe you didn't follow the earlier discussions. The material about the HP-35s was posted by a foreign-distribution partner (not HP), which likely "jumped the gun" by announcing a product that wasn't to be available until sometime in summer. I don't know how "final" the specs and image were. The distributor's site is still up.
The material was removed at the initiative or either the distributor or HP, likely due to the chatter and inquiries resulting from the leak, which certainly rejuvenated discussion in MoHPC Forum.
If someone has the original PDF spec page would they post it in this forum?
From the Terms of Use:
You agree not to post any copyrighted material unless the copyright is owned by you or by this forum.
-- KS
Edited: 10 June 2007, 4:12 p.m.
