Re: Pr Error HP-34C Message #2 Posted by Les Wright on 9 June 2007, 3:24 p.m., in response to message #1 by MikeG
I use a 34C with normal AA NiMH cells with the circuit completed on the right side of the compartment with a thin strip of aluminum foil. I found the old battery clip was too snug with regular AA cells and this works fine. It also makes it easy for me to pop out the cells and charge them in an NiMH quick charger. The Spice power adapter was intended for NiCads and will work with the NiMHs but takes forever to charge fully.
I was erasing my memory occasionally when removing batteries and it took time for me to realize that if I wasn't careful the foil strip would zip across the compartment and touch the contacts and discharge memory that way.
So I am wondering if your homemade clip could be the issue? Is the circuit being closed someplace it shouldn't be?
If your clip indeed is not the problem and the batteries are fine then I fear it could be the electronic innards and I hope someone here can guide you!
Les
