50g Connectivity Issues Message #1 Posted by brianh on 9 June 2007, 1:23 p.m.
Hello all! It's been a long time since I've posted here, but your (generally) positive reviews of the 50g drove me to add one to my HP collection.
However, there is one nagging issue with my calculator that forces me to seek help on this forum.
I can not get my 50g to connect with either of my two computers, each running WinXP. I have installed and unistalled the Conn4x software and drivers multiple times on each machine, with no luck. Also, when connected my XP resources window in My Computer does not recognize the calculator as a USB device.
I am using Conn4x v2.3, build 2436 and the USB driver that came with the calculator. All I get is the error message 'Error. No device detected. Check cable connections and the calculator'
I've scoured the calculator documentation and the HPMuseum form, but I can't figure out what's up. Since this is a subject that has not received a lot of attention I'm beginning to think I've got a bum calculator.
So, any help or suggestions would be appreciated. Anyone out there experience the same 'issue' and have a solution? As always, thanks in advance.
Brian
