Re: HHC2007 website updated with a surprise! Message #3 Posted by Jake Schwartz on 11 June 2007, 12:10 p.m., in response to message #1 by Gene
http://www.holyjoe.net/hhc2007/
Go here and click on the small image of the HP35 at the top of the page. The suprise is on the page it takes you to.
At this point, we have well over 30 registered attendees.
While you're there, consider whether you can come and register to do so. Enjoy time with fellow calculator nuts, ahem, enthusiasts and help celebrate the 35th anniversary of the HP35.
FYI, The registration list is above 40 now.
Also, below that HP35 brochure link is a new one called "other legacy literature" where there currently are nine high-res pdf scans of "ancient" HP calculator brochures, for your enjoyment. More will be added shortly.
See you in San Diego,
Jake Schwartz
