Re: 41s Message #12 Posted by Bill Wiese on 2 June 2007, 12:35 a.m., in response to message #11 by Hugh Evans
There's really little need for the horsepower of an ARM.
Packaging suitable for the casing, as well as power considerations and I/O appropriate for the existing HP LCD should be chosen first.
A TI MSP430 or PIC or other CPU along with an SPI serial flash memory (up to 2MB) and SPI serial RAM can work just fine to emulate an improved existing calc.
I'm betting the HP 35S uses low-cost COB (chip-on-board - chip bonded to PCB, covered with a glop of silicone) mounting, and that the PCB is heat-staked to the case.
A thin 'sub-PCB' will prob need to be fabricated, and existing CPU disabled somehow (foil cuts?). Tapping into PCB where exsiting chip is will be a bitch - there may be better places (test connector?) to get access without doing a whole new main PCB.
We really won't know until we can see the innards of a 35S.
Bill Wiese
San Jose CA
