Re: hp 28s repair Message #4 Posted by Randy on 22 May 2007, 9:18 a.m., in response to message #1 by Adrian
The 1000uf cap is the supply bypass/memory backup.
102k is a capacitor, the component next to it, an inductor. Those two form the clock tank circuit. The others are part of a voltage doubler for the LCD display driver.
The usual failure is not electrical but rather mechanical in nature - a loss in contact between the logic board and keyboard due to failed heat stakes around the keyboard connector area.
Quote: The case was easy to open and then repair if you have the right tools.
What tools would those be?
