Re: Graphing functions.. Message #2 Posted by James M. Prange (Michigan) on 8 May 2007, 1:45 a.m., in response to message #1 by PhysicsNerd
I rather seldom use the graphing features of the RPL models, so I'm not, offhand, certain of correct answers to your questions. I suppose that I could do a bit of research and find out easily enough, but on the other hand, you could do that.
Have you tried reading the fine documentation?
Or maybe there's a "training module" about graphing?
Or you could try an advanced search of the comp.sys.hp48 usenet group from http://groups.google.com/advanced_search?.
If you don't find an answer, then you could try posting a question to the newsgroup. In case you don't already use a newsreader, you should be able to access it from http://groups.google.com/group/comp.sys.hp48/topics.
Please be sure to include which model you're talking about with your question.
Regards, James
