Re: HP 41 doesnt work Message #2 Posted by Ron on 26 Apr 2007, 5:02 p.m., in response to message #1 by Juergen Richter
So far, every malfunctioning 41 I've seen has been either corroded contacts, or broken posts. Since your contacts are clean, I suspect it's a cracked/broken post. There is a screw under each foot, going into a post. If a post is cracked, there is poor contact between the electronics in the two halves of the calc. Depending upon how bad the posts are, they may be repairable. Check them out, and post your findings. I think many people here have experience repairing these.
