Equation library on HP48GII Message #1 Posted by Mike Ingle on 21 Apr 2007, 8:21 p.m.
The equation library on the HP50G is two libraries in port 2. I tried beaming these libraries from a Build 91 HP50G to a Build 39 HP48GII, and to my surprise, have a working equation library on the HP48GII. It also has 8KB free, so this is not terribly useful.
Send the libraries using RECN on the 48GII, since the GII has no port 2. Recall each library from the variable, purge the variable, then store it to port 0. If you do not purge the variable first, the larger library does not fit in memory. Turn the calculator off and on. You now have an equation library option in APPS.
