Re: hp50g programs Message #6 Posted by dbatiz on 6 Apr 2007, 7:29 a.m., in response to message #5 by Daniel Ripley
I'm still learning how to make things happen in the 50g myself, but I hope this helps. Any comments from more seasoned people are definately welcome.
There is a difference between a "Program" and a "Library". One of the apps you are trying to install is a library. I got the following instructions from the Stat49 Pro package available from HPCalc.org:
To install the library to port 0: (a similar procedure applies for port 1 or 2)
a) Remove possible older version with :0:1043 PURGE
b) Download the library to your HP49
c) Recall the library to the stack and purge the variable created by the download procedure.
d) Type 0 STO
e) Press ON-C
In step a) above to remove the library once it's not longer needed. The library number will be different :0:XXXX.
I hope this helps get the trig library up and running. The other program, I'm not sure.
Good Luck,
Very respecfully,
David
