Re: HP-IL Cables, where to get, how to make? Message #2 Posted by Eric Smith on 21 Mar 2007, 3:13 a.m., in response to message #1 by Egan Ford
I'm not aware of any "reliable" source for HP-IL cables.
Making your own is somewhat impractical, as the connectors were custom-made, and are not any more readily available than complete cables. If you had a bad cable, you could cut out a section and splice replacement cable into it. The cable HP used was more
flexible than most cables that one might find for replacement.
For a while there was a glut of NOS 82160A HP-IL modules in the used market, and it appeared that someone was cutting the captive cables from them and selling them separately.
The last time I purchased any HP-IL cables, a local electronics surplus store had a bin of them marked "fan cables". I happened onto them because I was actually looking for fan cables.
If you're sufficiently desperate, HP equipment resellers probably have some, but the pricing might make you ill.
