Utah teapot rotating on the hp50g Message #1 Posted by hugh steers on 6 Mar 2007, 6:29 p.m.
ok, try this guys, get http://www.voidware.com/tmp/v3.zip
and unzip it. inside there are files. V3, teapot, torus and dumbell.
put all these on your SD card and navigate to the SD card and Eval the V3 program. it should run standalone without the ArmToolbox.
you should be presented with a menu. make your choice and off you go. you might like to fiddle with the contrast too.
Warning: if you don't have enough free memory, it will crash the calculator (badly!). try torus first it's a lot smaller.
