Re: 48GX Repair - Won't Beep Message #2 Posted by Han on 5 Mar 2007, 9:31 p.m., in response to message #1 by Ron
There's improper grounding. Behind the battery holding area (upperhalf of the case) is a piece of metal that has a tab slightly bent away from the rest of the case. This metal tab needs to touch the metal from the lower half. At the moment, you're not getting the proper grounding. Either the lower section of the calculator near the 1, 2, and 3 keys is not properly closed (i.e. the four rivets there have not been reset) or the tab needs to be slightly bent (i.e. it was accidentally flattened out).
Edited: 5 Mar 2007, 9:34 p.m.
