HP-49g+ ROM update issues Message #1 Posted by Antonio Maschio (Italy) on 15 Sept 2006, 2:12 a.m.
I recently (9 hours ago) updated the ROM of my HP-49g+ from 3.54 to 4.01 (build 0092), downloaded from educalc.net.
I did the whole upgrade through a PC connection, and averything worked fine.
After the upgrade I have a couple of questions:
1) Is this the first ROM taht uses native ARM code, or is it still translated from Saturn code? Or: which is the first ROM to do this?
2) I have noticed that after the upgrade, the procedure for uploading files (right shift + right arrow) always fails the connection, while starting the same routine with XSERV always succeeds. Is this in relation with the new ROM or is it something that affects my PC/calculator/cable?
As far as I know (I couldn't do much practice on the new ROM, since I did the whole thing late at night, now I'm at work and I left the calculator home), these are the only questions that arise to me.
Did anyone experience some other issue after upgrading to the new ROM?
Thanks in advance.
-- Antonio
Edited: 15 Sept 2006, 10:15 a.m. after one or more responses were posted
