Re: HP41cv Display Message #2 Posted by Raymond Del Tondo on 14 Sept 2006, 3:38 a.m., in response to message #1 by Gordon Locke
the LCD of your HP-41 is 'bleeding' out,
propably the result from a hard knock on the floor or similar.
This damage is permanent, there's no chance to repair that display.
However, you can still use the unit for years,
as long as you can read the display.
HTH
Raymond
