Re: Rebuilding a 21/25/25C battery pack Message #2 Posted by Hal on 10 Sept 2006, 1:08 p.m., in response to message #1 by Bruce Bergman
Hi Bruce,
I think you just slice it open with an exacto knife, and then glue it shut again. However, I would advise against doing it this way unless you have a means to charge the battry pack outside of the calculator (such as a woodstock reserve battery charger). There are numerous threads in this post advising against connecting woodstocks to the AC adapter (as the risk of overvoltage to the calculator is to great).
I re-celled the battery pack in my 29C by cutting out the center strip, enabling me to install and remove the cells easily so I can charge them in an external battery charger, not in the calculator.
Cell retention in the pack is not affected, and the missing center strip is not evident when the pack in the calculator.
There is a metal colnnector strip welded between the cells in the stock battery pack, which will go away if you do it this way, but this has not been problematic for me, as long as I keep the ends of the cells and the spring contacts polished (with an eraser).
I use Duracell NiMH 2500mAH rechargables, which really go a long time in my 29C.
Hope this helps, and best regards, Hal
